05-08-2018
09:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-08-2018
09:42 AM
Hi @jason.bowman,
Thanks for the file you shared. It did find some errors when I ran AUDIT and I was able to purge out some unused content. Before I spend a lot of time working with it can you please also provide the xref files? I would like to make sure they aren't part of the problem. If you do not want to share those, please detach them from the drawing you sent and see if it still has the problem.
I notice too, that when I zoom extent, there is a lot of empty space around your model. Does cutting out the content, placing in a new file (closer to 0,0) would be good too) fix the issue?
John Vellek
