jason.bowman
29152 Vistas, 24 Respuestas
AutoCAD hangs/freezes when running commands, panning and zooming?
First off, this happens with whatever version of AutoCAD I use, I have 2016 and 2018 and the same thing happens in both, so my initial guess is AutoCAD is hammering my video card...
Whenever panning, zooming or trying to move an object in AutoCAD, it tends to hang, freezing for several seconds before it starts to cooperate again. We are using blocks with attributes on with different visibility's and the hang happens worse on these blocks... The block in particular there can be hundreds if thousands on one drawing as it is one we use constantly. Changing the block is out the question as it is a company wide standard, is there anything I can do to stop AutoCAD from freezing and hanging? It happens in most drawings, doesn't matter if I am in 2018 or 2016 and happens near enough every time I try to move, pan or zoom with a selection made after so much has been added to a drawing.
Drawings are usually between 2-4Mb so isn't much data within the drawing in a sense, but with regards to the block I mentioned, this data in the block is repeated hundreds/thousands of times dependant on the drawing in question.
However, it isn't just the block it hangs on, it also happens when trying to dimension between lines, objects etc, doesn't have any effect if I use the button on the ribbon or type the command on the command line, it's always the same outcome with the program hanging.
Have just had my C: drive changed in my PC and have gone from Windows 7 to Windows 10 so everything is fresh but am still having the same problem which is why I'm edged towards it being a hardware issue if anything?
OS: Windows 10 Pro 64-bit
AutoCAD version: AutoCAD 2016 & 2018
Processor: Intel(R) Xeon(R) CPU E3-1270 v5 @ 3.60GHz (2 CPUs), ~3.6GHz
Memory: 32768MB RAM
DirectX Version: DirectX 12
Graphics Card: NVIDIA Quadro M2000 (most up-to date)
