1590 Vistas, 4 Respuestas
XREF Moving from Model Space to Paper Space in AutoCAD
I am not sure if it moved to Paper Space, or was created in Paper Space.
All I was doing was to reload the XREF and found out that it reloaded on PS instead of MS
The original file was OK
thanks
DM
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Can you please tell me which version of AutoCAD you are using? Can you also etransmit a sample set of drawings that have shown this behavior?  I would like to examine the files and see if I can duplicate the problem.
John Vellek
imadHabash
>> I am not sure if it moved to Paper Space, or was created in Paper Space. <<
it's important to us to know that if it's originally created there or moved ( and how ) !!!! reloading xrefs didn't change placing for xrefs . please would you be more specific to give you direct answer . :cara_con_una_leve_sonrisa:
Imad Habash
en respuesta a: john.vellek
AUTOCAD 2014
Sorry but cannot release any sample drawings
ChicagoLooper
If your xref is in paperspace when it should be in modelspace, then you have 'attached' the xref on one of your layout tabs. Detach it then re-attach it, but this time, make sure you're in modelspace while executing the 'attach' command.
Chicagolooper
