gotphish001
768 Vistas, 8 Respuestas
Can't put a block on a palette
So I have this problem this morning that is making me want to smash my keyboard.  I made a simple block for a detail tag. It's not even complicated. It is a circle with a attribute consisting of 1 letter inside. Block works fine. I put the block into my dwg block library that I use for my palettes. Try to drag the block to the palette. It says block not found in dwg. All the other blocks that are in the library dwg drag to the palette fine. Yes I saved the drawing. I tried actually making the block in that dwg and still won't put it on palette. How can it say it doesn't exist in the dwg when that is were I dragged it from and made it there?
I started a new drawing. I can copy and paste the block from the dwg that it says the block is not in, into the new drawing. I can put it on the same palette from there and it works fine. It just won't let me do it from my library dwg. I've renamed it, remade it from scratch(in the library drawing or in another and inserted it into the library, purged it, all those things in different order. I just can't figure out why it works for every other block but this one. I've tried everything. It just doesn't make sense.
Edit: I also just tried putting the block on the palette from a new drawing which works. Then inserting the block from the palette into my library drawing which worked. Then deleting the block off the palette and putting it back on the palette from the block I just put in the library dwg from the palette. Nope same error saying block isn't in the dwg.
Nick DiPietro
Cad Manager/Monkey
