Kent1Cooper
en respuesta a: adamdanska
@adamdanska wrote:
.... I am mirroring on a perfectly straight horizontal line. ....
It doesn't look  perfectly horizontal in the images.  It has the variation in brightness characteristic of pixelation on a Line that is very slightly off the horizontal.  LIST it or pick it and look at its Properties, and see whether there's a small Delta Y value other than zero.  Or make sure your angular units are set to show degrees minutes and seconds [not just rounded to the nearest degree], maybe even down into decimals of seconds, or several decimal places of decimal degrees, and see whether LIST or Properties shows the angle the Line runs at being something other than 0 or 180 degrees.
Kent Cooper, AIA
