1911 Vistas, 4 Respuestas
Presspull issues
Some areas work some dont. please see screencast. thank you in advanced for your advise
Mike
imadHabash
en respuesta a: Anonymous
it will be great chance if you share with us your dwg ? also i want to remind to install the latest service pack from your Autodesk Desktop App .  ( as a try ) if you disable hardware acceleration from GRAPHICSCONFIG command
, any changes noticed ?
Imad Habash
Shay.Gaghe
en respuesta a: imadHabash
its poosible that objects are on top of each other?
what is your SELECTIONPREVIEW saying?
try reseting your usc
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
peterm
The rectangles are co-planar with the wall surface so AutoCAD can't determine which surface you want to work with.
Try selecting the edge of the door rectangle.
JessieMarsh115
It is sometimes helps to isolate the object using the below tool if presspull does not want to work with all objects showing.
