j.palmeL29YX
en respuesta a: Anonymous
@Anonymousschrieb:
this is the file after the problem happened
First I exploded your group, moved the parts to the correct position and created a new group. Than save, close, reopen - all is ok.
A second try: I made your group selectable, moved ( the parts to their correct position, made the group deselectable. Then again save, close, reopen - again all is well.
This means, I can't see any errors nor problems. I guess you must tell us more... (what you did exaclty). Maybe you can try yourselve what happens if you explode your group and create a new one (?)
cadder
Jürgen Palme
