418 Vistas, 7 Respuestas
boundary's bug or error or i miss something ????
i trying multiple boundary "bo"  some ares give me error ( a closed boundary cannot b determined )
when i cancel and try again the same (error-ed) ares  individually  or with other ares  it perfectely work
is this bug or error or i miss something ????
thank you all ..... (srry for bad English )
imadHabash
en respuesta a: Anonymous
Hi, would you please attache here your dwg sample for checking ?
Imad Habash
en respuesta a: imadHabash
i attched the dwg thnxx for your time
imadHabash
HI,
>> i attched the dwg thnxx for your time <<
Sorry ... nothing attached .!!
Imad Habash
i trying attch in replay
Shay.Gaghe
Unfortunately I cannot test the dwg as I'm away of office. But remember to include the whole area displayed while determining boundaries, and make sure you don't have anything under the area to be determined , use Overkill for that, also make some fine tuning in your gaps
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
imadHabash
sorry for the later reply ... would you please SAVEAS the drawing as AutoCAD 2013 version type so we can open the file .
Imad Habash
srry < i was away from everything
now i attached 2010 dwg
and thnxx for ur times
