timothy_crouse
247 Vistas, 2 Respuestas
Connect to database questions
I am in the process of creating a qualified parts list which will be stored inside a database.
I have watched the db connection you tube video "beyond basics"  and I see that OLE connections are pretty easy to use.  That scenario is fine if the database will be used by a small group but my goal is to post the db on a sever for a more networked solution.
I was thinking of using firebird which can be a stand alone "embedded db" or the same db can be created as stand alone and migrated to a server.
Has anyone connected autocad to non Microsoft product with success?  If so can you please provide some insight?
Thanks in advance
Tim C.
Etiquetas (1)
