08-25-2015
06:36 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-25-2015
06:36 AM
I think Vigayan got close to the idea. I will give this a try. this could speed things up, but it is not 100% automation as I would hope. The idea is to avoid having to manually edit the second block instances to match the first, and to update if you moved it from one "host" block to another. to do that we would probably need to do some programming? at any rate the method you suggested could reduce a lot of double entry. question, will ATTOUT reeturn the result of the field reference, not the field name? Thanks for the help, I will give it a try and let you know my thoughts.
