4268 Vistas, 7 Respuestas
Rectangle drawing with coordinate system
Hello everyone,
I just need some help with rectangle drawing. I must've clicked on something that changed the settings somehow. When I select the rectangle command and select the first corner point, my AutoCAD decides that this point is (0,0) on the coordinate system. When I move the cursor top-right quadrant, that's fine because the dimensions are the same as the (x,y) axes. However, if I move the cursor towards any other quadrant, the negative sign appears depending on the quadrant I am in. how can I return the setting to the normal where I can move the cursor to the left or the right and still get a positive value for the length and width of my rectangle.
Note: This happens only with rectangle drawing. AutoCAD works fine when drawing lines and circles!!
