725 Vistas, 4 Respuestas
04-25-2018
04:06 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-25-2018
04:06 AM
Editing attribute with multiple tags individually
We have purchased an add on program, AMOD8, which has proved useful in batch editing of attribute blocks on multiple drawings. In the program you identify the block and the attribute tag in a script file. The program then applies the script file to the identified drawing files.
I want to use the program to edit the attributes of revision blocks on a series of drawing.
The problem is that each revision block has multiple tags that are identical such as Revision Number, Date, Etc.
Is there a way to specifically target an attribute from multiple attributes with the same tag?
