cadfmconsultants
2477 Vistas, 15 Respuestas
AutoCAD DWG failing to share in Shared Design View (AutoCAD 2019)
SO, there's me.....trying to create a video to demonstrate the Shared Views new feature in AutoCAD 2019. The DWG file shares perfectly well. I log in to Autodesk Viewer. All OK so far. I then go to click on the link in Autodesk Viewer for my shared file. And I get the error message below. No actual error number...just 'processing failed'....oh, deep joy. I have now tried to log in to the Viewer three times and view the shared DWG. It failed (yep, you guessed right) three times. Anyone else out there have this issue?
Shaun 'CADjedi' Bryant
AutoCAD and Revit ACI and occasional Tinkercad user
Not Just CAD! - The Official Blog of CADFMconsultants
Twitter | LinkedIn
john.vellek
en respuesta a: cadfmconsultants
Hi @cadfmconsultants,
I admit that I have seen this numerous times.  How complex was your file? I found that I was having problems with 3D files  but couldn't isolate the issue. If you have the current file that failed, i would love to get it to the team to see if they can investigate.
John Vellek
cadfmconsultants
en respuesta a: john.vellek
John,
Not a complex file at all. A 2D office plan no less. I use it as one of my go-to files for video online training content. File is attached, so let me know if the team find anything. Thanks in advance, SCB.
Twitter | LinkedIn
john.vellek
I appreciate the file that you provided. I have documented this issue for the team and I believe it will get some attention very shortly. Thanks for your patience.
John Vellek
I have the same problem, i can´t see the file nor share it. i woul like a solution
https://autode.sk/2qXv5Ii
i have the same problem, i was testing the fuction and nothing, this is the link  https://autode.sk/2qXv5Ii
cloweRE8TC
en respuesta a: Anonymous
Same here, drawings uploaded but not available to view on my tablet.
john.vellek
Hi All,
The team is aware that this is not working properly at present and working toward resolving the issue as quickly as possible.
John Vellek
john.vellek
Hi @Anonymous, @cadfmconsultants@cloweRE8TC, and all others,
This service should be now working properly.  Please test at your convenience and let me know if you are still facing any problems.
John Vellek
cadfmconsultants
John,
Just so that you are aware, I had to delete ALL other shared views that had failed before I shared another design view that worked. I appreciate the work you guys put in, but this really should have been working from the release date of AutoCAD 2019.
If it helps, I used the Autodesk Viewer with the Beta Pi Release Candidate (RC) version of AutoCAD 2019 and it worked fine, so if there were any changes from the RC version to the full release version, it could be worth checking.
Meanwhile, all working, so thanks very much!
SCB.
Twitter | LinkedIn
john.vellek
HI @cadfmconsultants,
It was working for me too even in full release. I believe an update on the backend caused this issue.  I am glad it is working now though and hope that it remains stable. I appreciate your patience.
I know the views I tried to upload were not processed properly so I will likely need to remove them as well.
John Vellek
Kevin.Spear
I am having issues sharing views today. I can manually upload the drawings using the browser. But if I try to publish from AutoCAD 2019.1 (technically C3D 2019.1) it will fail. I deleted all current shared views, I logged out of my account within AutoCAD and am stuck. For now, I have to take a screenshot just to continue. The view does have an XREF, but that should not matter but maybe it does? See attached.
Kevin
Kevin
Kevin Spear, PE
john.vellek
en respuesta a: Kevin.Spear
Hi @Kevin.Spear,
I have been away from the office for a couple weeks and I apologize for my delayed response.
I opened your files (in AutoCAD 2019) and ran AUDIT as both files had some corruption. Once they were cleaned up I created a new shared view and had no issues at all.  Here is a link
John Vellek
DWEN
Sorry but it is not working.
Loged out and in agen with my account, but is still is the same problem.
When I want to make a shared view, I got the message:
"There is a mistake while sending the question"
john.vellek
en respuesta a: DWEN
Hi @DWEN,
Can you share the drawing file that gives you this error message when you try to share it?  What is the file named? I am curious if there are any special characters that might be breaking this process.
Can you also do a screen capture of this error message? Does it show up in the browser?
John Vellek
john.vellek
Hi @DWEN,
Is this issue still happening?
Here are some things to check:
  • Run RECOVER or AUDIT on your drawings
  • If a specific Layout is the issue, check the applied pagesetup for and unusual plot size or plot area.
Additional troubleshooting steps:
  1. Run SHAREVIEW and publish current sheet, 2D-only, no properties
  2. Run SHAREVIEW and publish current sheet, 2D & 3D, no properties
  3. Run SHAREVIEW and publish current sheet, 2D-only, WITH properties and watch task manager for amount of RAM used. If it goes up over 12-15GB then that would likely cause AWS instance to die.
  4. Run SHAREVIEW and publish all sheets, then all sheets with properties
John Vellek
