Ajilal.Vijayan
en respuesta a: dc
Hi dc,
Welcome to Autodesk Community.
By using fields you can achieve this.
While inserting/After inserting the second block right click inside the Value box of attribute value to select 'Insert filed'
  1. Select Object from Filed category
  2. Select Object from Field names
  3. Click the Block reference button from Object type and select the First block.
  4. Then select the attribute tag from Property filed
  5. Click ok to inherit the first block attribute value to second block.
  6. Multiple instance of second block can be made by simply making copies.
Click the +sign to see the image and please find the attached drawing also.
Spoiler
