dc
1422 Vistas, 5 Respuestas
Attribute inheritance from different block
Hi folks,
I am looking for a method to inherit attributes from one block to another, perhaps using fields, and using plain vanilla AutoCAD 2016.
One block is the "Device" block and carries a "device name" attribute
A second block is placed inside this block (not nested) and also has an attribute named "Device Name". It needs to match the name of the Device Block that it is located within.
Multiple of the second blocks are placed inside the Device block.
We would like to automate the "Device name" attribute of the second block so that it inherits the name of the Device block.
Can anyone think of a way to do this? Would this require lisp or C progrmming, or could it be done within the application?
Thanks in advance for your thoughts.
