leeminardi
en respuesta a: Anonymous
It appears that you are zoomed in by a lot!  Fit points are not a direct component of how NURBS (splines) are stored. Give the list command and select the spline.  You will see a list of control points (also known as Control Vertices or CVs) and fit points along with a tolerance for the fit points.   The fit tolerance is used when AutoCAD calculates appropriate CVs to approximate a NURBS that will pass through, or near, the fit points you specify.
lee.minardi
