568 Vistas, 2 Respuestas
Spline Fit Point Accuracy
Hi, I have a problem when I use this application. Everything's normal until I make this spline, it looks like the spline doesn't fit with its point, here I attach a picture of the spline.
The point is belongs to the spline on its right. But why the spline doesn't fit the point? I already tried to REGEN a couple times but nothing happened...
Etiquetas (4)
j.palmeL29YX
en respuesta a: Anonymous
If possible please upload a .dwg including the problem.
cadder
Jürgen Palme
leeminardi
It appears that you are zoomed in by a lot!  Fit points are not a direct component of how NURBS (splines) are stored. Give the list command and select the spline.  You will see a list of control points (also known as Control Vertices or CVs) and fit points along with a tolerance for the fit points.   The fit tolerance is used when AutoCAD calculates appropriate CVs to approximate a NURBS that will pass through, or near, the fit points you specify.
lee.minardi
