imadHabash
en respuesta a: Anonymous
>> Is there a way to flatten it or convert it to 2d?  <<
Yes you can by FLATTEN command . i do it and it's done . just wait and watch your screen when the command is proceed.
>> Please don't judge it too harshly, the file is a bit of a mess.. <<
This is the issue ... when i clean all the model and purge the dwg and detach all those xrefs in your dwg i found that pasting is normal now ( see attached dwg file ) .
from your  firsy post >> If I select the objects, ctrl+alt+C and paste it into the same model space <<
there is NO such a command maybe you mean some thing else .
All the best .. :cara_con_una_leve_sonrisa:
Imad Habash
