nrz13
756 Vistas, 9 Respuestas
AutoCAD 2018 REGEN bug when multiple drawings open
When I have several drawings open (approximately 10, using more than 1GB of system memory), AutoCAD no longer refreshes the screen after completing a command. So, say I move an object, the object shows up where I moved it, but a ghosted version, often with other visual artifacts, remains at the old location.
When I manually refresh (RE) or scroll-zoom in model space and paper space, the old location and artifacts disappear. In paper space model space viewports, only scrolling works to refresh the screen. If I turn off Hardware Acceleration, the problem goes away, but then my crosshairs blip whenever moving them and I don't get the benefits of the hardware acceleration.
I'm using a certified card: Radeon Pro WX 5100 (driver 22.19.693.256, 2017/12/01).  Full specs below.  Do note that this issue is also happening on my home computer, which uses an NVIDIA graphics card, so I think we can rule out hardware and video graphics drivers – this appears to solidly be an AutoCAD 2018 problem, as neither computer has this problem using AutoCAD 2016.
Video attached below.  @john.vellek My support case from Feb. 8, which is still awaiting a response from Autodesk, is 13888592.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
