527 Vistas, 5 Respuestas
command line version for commands
I want to know how to enter commandline version of all commands in autocad for creating script files.
anybody knows about this pls just reply me.Thanks.
cadffm
en respuesta a: Anonymous
The normal command with "-" in front
IF a commandlineversion exist!
Easy to try.
If you ask for all commands you can Handle in scripts: I dont know about such a list.
All commands with first character "-" sure.
And commands with dialogs works too, but need a Userinput.
command: BLOCK vs.
Command: -BLOCK
In automation like Script Autocad start the commandlineversion as default.
But for testing i use -BLOCK, so i am using -BLOCK in Scripts too.
Variables
FILEDIA for File-chooseing dialogs
_.-LAYER
_make
01234
_co
1
01234
_.line
0,0
1000,200
;DIALOG-START
_.OPTIONS
;DIALOG-END
_.circle
500,100
250
_.ZOOM
_e
F1 help
example for LAYER commandlineversion = "-LAYER" -> CLICK
Sebastian
ВeekeeCZ
HERE is a list off all dash* commands available.
en respuesta a: ВeekeeCZ
ok thanks for your reply but i couldn't find "find" command in that list how to know commandline version for "find"
ВeekeeCZ
Well, sorry to say that, but you either did not search good enough or read good enough. If latter, re-read especially the 2nd line of @cadffm's reply. Then consider to apply the advise on the 3rd line of @cadffm reply.
cadffm
Not available, only as Dialogversion.
Sebastian
