- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Obermeitkc147 wrote:
... I've been trying multiple variations of that and experimenting with different types of grips but I haven't had any result like you described.
So I put a few Blocks in my drawing, then here's a Command-line history [the black parts]:
{With no command active, I picked in empty space to start a crossing window for noun-verb-mode selecting them}
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
{I picked the opposite corner of the window, so I had several Blocks selected that way.}
Command:
{I picked on one of their insertion-point grips}
** STRETCH **
Specify stretch point or [Base point/Copy/Undo/eXit]:
{It was showing moving the one whose grip I picked on; I pressed Enter, and it changed mode for all of them collectively, to:}
** MOVE **
Specify move point or [Base point/Copy/Undo/eXit]:
{and they all Moved together to where I took them -- end of operation.}
What happens when you follow the same procedure? Can you copy/paste a command-line history like this?
