350 Vistas, 5 Respuestas
Importing PDF into AutoCAD
Can a scan of print be imported into Auto Cad so that I can turn it into a working dwg file? The only pdf we can find for this drawing is a scan of a print. From what I am reading the only thing I can do is attach this scan ( second generation pdf) and redraw it using the scan pdf as a base.
When I try to import this pdf (scan of a print) all I get is basically a copy of the pdf in my drawing. It basically acts as a block that cant be exploded.
Hopefully I described this properly as I am just getting back into AutoCad. I am quite a few releases behind (release 13).
