TheCADnoob
en respuesta a: Anonymous
I'm not sure we can necessarily help you with your problem. It sounds like the bulk of your problem is solving the jigsaw puzzle you have created.
Some command you might find helpful:
GROUP: allows you to temporarily create groups of objects
SELECTSIMILAR: Sort of self explanatory, but it allows you to select similar objects and if you set the setting you can select by color.
JOIN: allows you to join lines together into a poly line.
ROTATE
MOVE
MIRROR: (unless there are obvious 'sides' to the cloth)
The way I would approach this is by laying out a 36 in tall rectangle on the drawing and place everything inside it then delete that rectangle after.
Good luck and let us know if you get stuck along the way.
Also it should be noted that AutoCAD for MAC is significantly different than what is available to the PC so you might want to check out the MAC forum if you have technical difficulties
https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
CADnoob
