1747 Vistas, 3 Respuestas
Editing and Nesting DXF files
I am a new user of Autodesk LT.  I have installed it on a MAC.   I have digitized the panels of a Flying Dutchman sail.   The cut and seam lines of the panels are in DXF format.   I need to encode the lines in two different colors to send the digitized pattern to an Autometrix plotting/cutting machine.    A red color indicates a cut.   A green color indicates a draw.   There are about 25 panels that comprise the sail.  Once all the panels are properly encoded by color, I need to nest the panels onto a 36 inch roll of sail cloth.    The widest panel is 36 inches wide and uses a straight edge of the sail cloth.  The longest panel is about 3.5 meters.   I see to how to change the color properties of individual panels, but it is somewhat awkward to select seam and cut lines if they are close together.  Everything has to be one layer.   I do not know how to nest all the panels onto a 36 inch roll.   I would like to manually nest the panels to make sure straight edges are lined up properly on the roll of sail cloth.  Any help would be greatly appreciated.
Thank you, Doug.
Etiquetas (3)
