04-14-2018
12:15 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-14-2018
12:15 PM
It CAN select objects by color, but you had only one CIRCLE in color yellow and it is selected before as source object and after the command, as result.
The objectTYPE is ever set as a filter!
Draw 3 lines, 3 circles and 3 text, set only two of each to yellow, select on yellow line and one yellow text,
use selectsimilar and check the result to understand how the command works.
Sebastian
