4967 Vistas, 15 Respuestas
04-14-2018
05:58 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-14-2018
05:58 AM
SELECT SIMILAR Command is not working as it should.
I made different layers .
Then i draw different objects on these layers in different layers.
Then i invoked SELECTSIMARAL command and in setting i checked colour.
So that the selection happen on the basis on colur.
See in the screen-shot 1 circle , 1 rectangle & 1 polygon are drawn in yellow colour .
But when i click on yellow circle to see the effect of SELECTSIMILAR command only circle is selected leaving behind the other two objects of the same colour unselected.
Why is it so ?? I'm using AutoCAD 2018 .
