- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
SELECT SIMILAR Command is not working as it should.
I made different layers .
Then i draw different objects on these layers in different layers.
Then i invoked SELECTSIMARAL command and in setting i checked colour.
So that the selection happen on the basis on colur.
See in the screen-shot 1 circle , 1 rectangle & 1 polygon are drawn in yellow colour .
But when i click on yellow circle to see the effect of SELECTSIMILAR command only circle is selected leaving behind the other two objects of the same colour unselected.
Why is it so ?? I'm using AutoCAD 2018 .
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You have to use Qselect for that. Selectsimilar doesn't do that.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Circle+Color in your Example.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If SELECTSIMILAR can't select objects on the bases of colour then why this Option (Colour) is there in the settings on SELECTSIMILAR command ??
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Good Question
One that can only be answered by the people who wrote the software.
Maybe Autodesk can provide an answer for you.
We, as experienced users, can only tell you what the software can do
We use the software provided to us, and we have to abide by the
rules of the software.
Michael Kovacik
--Cad (28 yrs)
---Cadkey (4 yrs)
---Inventor (4 yrs)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The objectTYPE is ever set as a filter!
Draw 3 lines, 3 circles and 3 text, set only two of each to yellow, select on yellow line and one yellow text,
use selectsimilar and check the result to understand how the command works.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sebastian
the way you are explaining it is exactly as I said in my post.
when you select one yellow line and one yellow text and use selectsimilar,
and change the settings to colour, or alternatively change
selectsimilarmode to 1 which is colour (same effect)
it selects all the 2 yellow lines (not the yellow circles)
and the 2 yellow texts (again not the yellow circles)
therefore select similar CANNOT select objects by colour, it defaults to object type,
and selects the yellow object types picked NOT all yellow objects.
Therefore to select all yellow objects (regardless of their object type) you have to use QSelect.
This is as explained in the AutoCAD Help itself, a screenshot of which was in my previous post
Mike
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
For only color filtering
QSELECT
and
FILTER
and with installed expresstools)
SSX
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I see how filter works - great
I can't figure out how to apply ssx to a command.
Is not filter and ssx, the same as Qselect
or are they different?
Mike
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
a. Filter all lines with length 15
b. Filter all circles and lines with color2
c. Filter all yellow lines and red circles
d.Filter for objects with normal vector not 0 0 1
e. Save the search-filter to use multiple times, next week, next month.
No the commands are not equal.
Some hints.
QSelect
Select only objects in current space.
You can search for not stored properties like the length of a line.
SSX
Its a cutted/little commandline version of ssget, the Lisp-function object selection.
Its the only way of all three for using in commandline, so it is helpful for menumscros and scripts
Filter
Old DXF based filter, search the whole drawing and offer much of the Its a powerful GUI version of ssget, the Lisp-function object selection.
The dialog remember your last setting and you can save your filterlists, so you csn use it in another file or another session.
And many more.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks Sebastian
Filter and ssx are both new to me.
Learning new things all the time, even
after using AutoCAD for 20 years!!
Will try it out, still struggling with SSX.
If I have any problems I will get back to you
Mike
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Okay Sebastian
Time to call for help!
I can get Quickselect to do a, b, c but not d,e (I don't think it can)
I can't figure out how to a,b,c,d,e, with ssx. I need guidance or a pointer to a nice tutorial
I also can't figure out how to do a,b,c,d,e with filter. Once again guidance or pointer to a tutorial
Can you guide me to something on vectors too. I know what vectors are from engineering maths,
I know what they are in 3d space, I'm not quite sure how they are identified in Autocad
Mike
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No one of that function can all a-e filter, thats the point.
You asked "all the same?"
My answer: No, try to filter the five examples.
Length of <some objecttype> is possible only with QSelect for example.
I will write more in the next hours.
"I know what vectors are from engineering maths,"
Exactly! Autocad works in a 3D room and all objects are in this 3d space, all points/coordinates are x,y,z.
95% of objects has there own object-coordinate system or better normal vector.
Sorry that i can't explain it in this language (i am happy enough that you understand my other posts).
To filter normal vector was only one example to show what FILTER and SSX can, but qselect not.
Yellow circle OR red lines,
thats not possible for qselect and ssx, but FILTER can filter this.
Read you later
Sebastian
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In this case the color of the object is bylayer. Change the circles to a color and you will see the difference.
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@MikeKovacik4928 sorry, no time for larger answers these days.
But after @GrantsPirate posting: I dont know what he talk about in this case, but i saw one thing in your picture of first post:
You talked about " in yellow colour ". Yes, it is one of thousends yellows.
But Truecolor is a very special thing in AutoCAD (for plotting) and in DXF ~ and so for selection with ssx&filter).
For testing use only Autocad Color Index / ACI-colors (color 1-255), it is to hard for me to explain it now in english why not TC or what is special.
ByBlock= Color0
ByLayer= Color256
(use FILTER - add selected Object, so you can get this information too)
Note: SSX create (only) a selectionset, not a griptset.
Use ssx, you get answer from acad: 2 found.
Now you can use the selectionset if a command ask for an object-selection
via selection mode P = PREVIOUS
move<enter>
select objects: P<enter>
Or set Pickadd=2
Use SSX
Start command SELECT
cu
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for all your reples. Will look at them over the next few days.
I only do this at home, not at work, and my time is limited.
Will revert back to you
Mike
