BeKirra
en respuesta a: Mark_C_123
Surely I have cleaned the layers on the drawing file.
There most likely is a pre-loaded *.lsp or other add-on with your AutoCAD.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
