04-10-2018
06:50 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-10-2018
06:50 PM
-purge is the command to use. Select "All" when you see the options in the command prompt.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
