Mark_C_123
665 Vistas, 13 Respuestas
CANNOT DELETE LAYERS!
I am working on a plan and cannot permanently delete all the layers in the drawing. I am pretty sure I have tried everything hence this post but to save some time; tried with no success - purge, audit, laydel, new drawing.
The layers do go but all pop back up when re-opening the file.
I have attached my working CAD file and all I want to keep is the current Lot Bdy layer. All the rest can go..
cheers
BeKirra
en respuesta a: Mark_C_123
-purge is the command to use. Select "All" when you see the options in the command prompt.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Mark_C_123
en respuesta a: BeKirra
No good, Purge doesnt work. Did it work for you? If it did please re-attach my cad file
BeKirra
It works perfectly for me.
The only layers cannot be removed are "0" and "LOT_BOUNDARIES". The latter cannot be delected because it is used by the geometries on your drawing.
HTH
X² + Y² = C²
Mark_C_123
Yes I know they cannot go. have you re-opened the plan and they are still all gone? can you please attach the file so I can see. Thanks
BeKirra
As attached.
X² + Y² = C²
Mark_C_123
Thanks for attaching. But still no good!
I downloaded your file, moved onto my desktop and open it straight from there and they are all back.
It shouldnt even possible??
See my attached screen shot.
BeKirra
Surely I have cleaned the layers on the drawing file.
There most likely is a pre-loaded *.lsp or other add-on with your AutoCAD.
X² + Y² = C²
Mark_C_123
I dont think either of them, I am going to put it down as a weird glitch in 2016. I just opened my original file in a newer version of AC and purge worked fine. what a stupid problem to have.
Thanks for your help mate
BeKirra
What if you open my copy in your new version of autocad?
IMO based on your description so far, there is an add-on auto-loading pre-set layers when you open any drawing.
IOW please check if this happens when opening other drawing files in v2016.
X² + Y² = C²
Mark_C_123
Your file opens fine in newer v. I have opened my ''appload'' and checked all my lisps that load on startup and nothing out of the ordinary in there. Any ideas?
BeKirra
Check if there is a file name similar to "acaddoc.lsp" (this is a file that will be loaded automatically when AutoCAD statrs). If it is found, open it with Notepad.
Let me know what you see in the file.
X² + Y² = C²
Mark_C_123
Thanks mate, I found it!
Why someone created this is beyond me. :cara_con_una_leve_sonrisa:
BeKirra
It looks likely you have a untitled CAD manager/IT patroller in your work place.
Emoticono feliz
X² + Y² = C²
