Kent1Cooper
en respuesta a: Anonymous
Even easier on AutoCAD, I would think [I haven't set up a comparable test situation], than LAYMRG or MATCHPROP, would be [if you haven't tried it already] CHPROP / select everything / Layer / [whatever Layer you want].  Or even just pre-select everything, and in the Layer pull-down pick the Layer you want.
These approaches won't eliminate all the other Layers as LAYMRG would, but you can PURGE them afterwards.
You could do it in chunks if it can't handle it all at once.
Kent Cooper, AIA
