513 Vistas, 2 Respuestas
Need help with UCS repositioning
Hello, I am trying to learn Autocad and I am using version 2015 because I'm trying to follow a YouTube guy who is an autocad instructor.  The video is about 20 mins long and after attempting to follow it 4 times from the beginning each time I am 100% successful until I get to 12 minute point each time. At this point he is moving the xyz indicator from one position on the 3D drawing to a point at the top which is the center of a hole.  This is where I get stuck, he then moves it down on the Z axis and somehow repositions the X access to draw a new line for the next tube extrusion point.  When I try to do it my xyz ucs indicator gets messed up and doesn't turn the correct way no matter what I try to do.  Any assistance would be appreciated, I've tried it 4 times and each time get stuck at the same place in his video.  Here is the link to it... https://youtu.be/XSRn0maJRfg
Thank you,
Mike
