AEC_Cadd
en respuesta a: john.vellek
The OCE is a TDS 400 wide format printer. Has always worked with every AutoCAD version. The printer on my desk is a HP8600 and that also won't plot. AutoCAD just hangs up when I try to print to it. I did migrate my plot settings. I am not using the old pc3 files. I have tried to print to the system printer of the OCE and same results. Just can't get anything to print. If I let it sit for 15 or 20 minutes, then cancel out of AutoCAD, I get the message "Closing your session will cancel the active plotting operation".
If the C3D 2019 is anything like the Trial Ver. of AutoCAD, we won't be able to use it and will have to stay with the 2018.
