- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I downloaded the trial ver. of AutoCad 2019 and found that it will not plot to either the HP on my desk or the three wide format plotters that we have in the office. Is that by design because it is a trial ver. ?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What is your OS?
Which HP devices are you trying to plot to?
What driver versions are you using? are you aiming for Windows drivers or old Pc3?
And which older AutoCAD version are you using now?
Trial versions are fully functional, they just stop running after 30-days.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @AEC_Cadd,
Please tell me the printer models and operating system you are using.If they are HP devices you might try the Universal driver available from HP.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hard drive. I am trying to plot to a HP 1050 large format printer or the
OCE large format plotter. I understand that the 1050s don't work well with
Windows 10 but the OCE has always worked great with any system. The HP
printer is a 6800 I believe - I am not in the office at this time - but it
works well with 2018 ver. When I try to plot, AutoCAd seems to hang up and
if I try to quit out of AutoCAD, it tells me that the printing file will be
cancelled. I have let it sit for 15 to 20 minutes and no plot is created.
I hope that the C3D 2019 will work better than the trial ver. of AutoCAd
2019.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @AEC_Cadd,
Which Oce model are you using and which driver is involved? When you installed AutoCAD 2019 did you migrate your plot settings or create new PC3 files from scratch? Typically I like to create new PC3 files for new software installs. The CTB files typically survive a migration without any issues.
Please try printing to the System Printer of the Oce and not a PC3 file and see if that makes any difference.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The OCE is a TDS 400 wide format printer. Has always worked with every AutoCAD version. The printer on my desk is a HP8600 and that also won't plot. AutoCAD just hangs up when I try to print to it. I did migrate my plot settings. I am not using the old pc3 files. I have tried to print to the system printer of the OCE and same results. Just can't get anything to print. If I let it sit for 15 or 20 minutes, then cancel out of AutoCAD, I get the message "Closing your session will cancel the active plotting operation".
If the C3D 2019 is anything like the Trial Ver. of AutoCAD, we won't be able to use it and will have to stay with the 2018.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am using Windows 10, the OCE is a TDS 400, the HP printer is a HP Officejet Pro 8600.
I am not going to try the Universal driver as C3D 2018 works without it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @AEC_Cadd,
For the TDS 400, is your firmware fully updated? Please tell me your driver version. It appears that last driver from Oce (Canon) is from last June and can be found here.
There is a driver cleaning utility available here to remove old drivers.
Regarding the HP printers, you should be able to add the universal driver and point to the same devices without affecting the existing driver installations. Just treat the installation of this driver as a new printer.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Our OCE rep sent out a tech person to check the drivers. All drivers are up to date.
The HP 8600 Office Jet will not plot.
We just bought a HP Color Laser Jet M553X with the most recent software. It will not plot
I can't even create a PDF when I try to plot to Adobe.
AutoCAD 2019 DOES NOT PLOT.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @AEC_Cadd,
OK, then the problem is not likely the plotters but rather your installation of AutoCAD 2019. Is it able to produce a PDF using one of the built in PDF drivers? If not, I would Try a Reset Settings to Default. If that does not work then I suggest a clean uninstall and reinstall.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
OK, perhaps tomorrow if I have time, I'll uninstall and reinstall.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I reinstalled AutoCAd 2019 and this time did NOT import settings from my 2018 Ver. Now with the new import - everything works. It will plot to HP printers, OCE plotter and now am able to make a PDF.
I'll remember that for all future installs.
Thanks for your help
