437 Vistas, 4 Respuestas
HATCH
Hi
how to changes hatch to follow roof direction? I am still beginner so i need help..
i want the hatch to follow the direction of rain fall down..i want the hatch to follow the direction of rain fall down..
Alfred.NESWADBA
en respuesta a: Anonymous
welcome @Anonymous!
You have to create separate hatches for each roof direction.
If an existing hatch should be modified simply select it, then you get it's properties shown in the ribbon and there you can also adjust the rotation.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
>> how to changes hatch to follow roof direction? <<
you have to change the Angle on every new and different roof direction .
Imad Habash
en respuesta a: Alfred.NESWADBA
Hi
thanks for your reply,i already try it..and its help..after create different hatch and using angle
thanks a lot
en respuesta a: imadHabash
Hi
thanks for your reply,i already try it,after create different hatch and using angle, also the picture is really helpful to figure it
thanks a lot
