asutton
850 Vistas, 3 Respuestas
Can I r-click repeat last command, ctrl+r-click shortcut menu?
Hi all.
I use right-click as repeat last command, but I can see the use of the right-click shortcut menus. Can I maintain right-click as repeat last command and make CTRL+right-click the shortcut menu? Essentially this is the same functionality as SHIFT+right-click for the OSNAP menu.
I've poked around in the CUI but cannot work out how to unleash this functionality, if you even can...
