en respuesta a: john.vellek
Thank you for the warm welcome!
Honestly the last autocad version I was using regularly was of 2006 LT -now, all of a sudden I need to clean up this dwg in autocad 2017.
Not even familiar with the interface, never used autolisp before.
Eventually I'm aiming to get the 3D out of the dwg that we can load in into archicad. Meshes would be enough, at this point I can't be sure if it ever was a solid object.
Intended process is something like exporting to fbx>>>converting the fbx to obj>>>removing doubles in blender, exporting 3DS>>>importing as object.
Sorry but I can't share the file in public.
Also as an update, could export each layer as a separate dwg file.
Just guessing at this time, batch converting the dwg-s to obj files would be the best. (And batch importing to blender right after.)
Will try messing with yet another lsp file, that I found here.
