john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Without seeing your drawing I am making some guesses.  First, try using ATTSYNC or BATTMAN to update the text in your blocks if they are attributes.  Next, tell me what text style you used. Is it ANNOTATIVE?  What is the variable ANNOALLVISIBLE  set to in your drawing? Try setting it to a value of 1 and see if that helps.
You are welcome to attach your file to a post so I can examine it.
John Vellek
