3480 Vistas, 3 Respuestas
Text on title block not showing
HELP!!
For starters I'm a CE major student in an autocad class. We've been given 700ish point (X,Y,Z) to plot. I've created all necessary blocks to be inserted etc etc. So when i go to use the auto input command to input these points with their correct titles via pasting a copied word doc, i can only get the ddptype point to show. No title, no elevation. Now i should mention that when I originally went to edit the blocks attributes my scale was 1:1, while the mspace scale is 1":200'. First go round my titles and elevation showed up but much too large. So i went back to the block editor, edited my attribute and text size to the needed 1/64" and made sure my scale in the block editing screen was set to the 1':200'. Went to reinsert and bam, no text.
 Any help will be greatly appreciated. Thanks
