cadffm
en respuesta a: Anonymous
If I understand right:
You have a template.dwg with Blocks,
added one (dynamic) Block"A" to a Toolpalette, this step created a insertion Toolpalette tool (i am not sure for the right english word for this)
You create a blockreference of that Block"A" in another Testfile.dwg, edit the Block"A" in template.dwg&save this file.
Back in Testfile.dwg you are using rightclick->redefine for Block"A" and now.. the old created blockreference of Block"A":
1) Is updated well, has the new feature and perhaps the edited objects/properties.
but
2) The VALUE of one or more dynamic properties are reseted, right?
Answer: You changed something which Acad can not handle.
>> (add a new visibility & new geometry)
That alone is NOT a Problem, I am sure between create the "old" blockreference and your last step "(add a new visibility & new geometry)" there
was more/other changes on this blockdefinition (in Testfile.dwg)
For example: Delete and recreate an parameter.
Sebastian
