en respuesta a: Anonymous
Sooo... What IS the answer?
I'm on LT 2018 and having dynamic blocks reverting to a previous version once I hit 'redefine' in the tool palette. I edit the block (add a new visibility & new geometry), then exit the block editor. I test the functions of the block. All is well. Then save the file. So far so good. Then update the block in the tool palette with 'redefine'. Boom, the changes are gone.
I'm not understanding the answer as it is stated... Am I suddenly forgetting a step in the process? If I've been doing it wrong all along, then ...why would it have worked before and suddenly not now??
UPDATE:
Still stuck on this one. I also tried bringing the block into a new file, making the changes, changing the block name, and copying that to the original file (source file). But when I add THAT renamed block to the palette, there is a different error where it is listed in the palette but with a big white square instead of a picture of the block. Hmm....
If this were really important to my project, I'd be pulling my hair out right about now. Any suggestions?
