Kent1Cooper
en respuesta a: Karol-Or
[EXTRUDE vs. PRESSPULL depends on exactly what kind of result you're after.  EXTRUDE has the advantages over PRESSPULL that you can Extrude along a Path, or with Taper, if either of those is needed.  PRESSPULL has the advantage that you can do it on a shape bounded by more than one object as in your example, without a middle-man Region as in my suggestion.]
Kent Cooper, AIA
