Karol-Or
14829 Vistas, 6 Respuestas
Extrude not making a solid
I joined the parts, properties say it's planar and closed but still creates surface.
I exploded the join since i want to keep the straight lines as straight as possible, and if i join to the curve it'l be a spline
Kent1Cooper
en respuesta a: Karol-Or
Try making a REGION inside there.  That will Extrude into a 3D Solid.
Kent Cooper, AIA
WarrenGeissler
You can use PRESSPULL for an enclosed area.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
john.vellek
Hi @Karol-Or,
I had no problem creating a solid from the outline using PRESSPULL as suggested by @warren.geissler.
John Vellek
Kent1Cooper
[EXTRUDE vs. PRESSPULL depends on exactly what kind of result you're after.  EXTRUDE has the advantages over PRESSPULL that you can Extrude along a Path, or with Taper, if either of those is needed.  PRESSPULL has the advantage that you can do it on a shape bounded by more than one object as in your example, without a middle-man Region as in my suggestion.]
Kent Cooper, AIA
Make it sure that your object are joined together you can you use joint command
Kent1Cooper
en respuesta a: Anonymous
[Careful....  There is no JOINT command.]
Kent Cooper, AIA
