404 Vistas, 4 Respuestas
my unit set up is in inches
now all my drawing are in cm
and when check the area it shows
260 cm  *207 cm  shows  53820.0
how can i get the answer in m sqr
cadffm
en respuesta a: Anonymous
EDITED,sorry
260cm*207cm=53820cm²
Nothing to do with Inch!?
You can not change the units for menus, if you want a Text with "5.382", that possible (create a field with factor 0.0001)
The question now: Where do you want to see 5.382?
It is not possible for 'Propertiepalette' or command LIST or command AREA.
But if you want to display the area in a Text, Mtext or Attribute by a FIELD, that works.
Sebastian
peterm
Just move the decimal point 4 places to the left.
en respuesta a: cadffm
thank you so much for your answer
it worked for me
how to find the m sqr area of the same room using 'list'
]LI +ENTER]
