473 Vistas, 1 Respuesta
modify center line system variables
i have just been upgraded from autocad 2016 to 2018  and found the "center line" command (from 2017 )
i found the system variable commands , but from what i can figure out they have to be set on everysheet i use the center line command.
is there a way to set / change the "base" system variables so when i use the center line command  the system variable stay constant when i switch sheets  and not have to change it every time
