474 Vistas, 1 Respuesta
modify center line system variables
i have just been upgraded from autocad 2016 to 2018  and found the "center line" command (from 2017 )
i found the system variable commands , but from what i can figure out they have to be set on everysheet i use the center line command.
is there a way to set / change the "base" system variables so when i use the center line command  the system variable stay constant when i switch sheets  and not have to change it every time
WarrenGeissler
en respuesta a: Anonymous
All of the CENTER* system variables are Drawing-Specific variables. If you want to change them, you should do so in your drawing TEMPLATE (DWT file).
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
