gotphish001
en respuesta a: Anonymous
Autocad doesn't randomly decide to play copies. It sounds more like your mouse is going bad. It's an easy test. Just use another mouse for a day or two and see if it does the same behavior. There's no variable that controls random mouse button actions though.
As far as the changes from 2004 to 2017 I'm not sure there's any comprehensive guide. My suggestion is if you notice something that's different in 17 over 04 don't try and make 17 act like 04. Try and use it the way it works in 17 as it's most likely changed for the better. If you try to make everything in 17 work like 04 then you will constantly be fighting the software and it will continue with every new release you get as it will be closer to 17 than 04.  The forums are a good resource. As you find things that are different and have questions about how something works or what it is for just ask. Don't be afraid to ask what seems like a easy question as those are also the easiest ones to answer. :cara_sonriente_con_la_boca_abierta:
Nick DiPietro
Cad Manager/Monkey
