- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am using AutoCAD 2018 and can not seem to figure out what is going wrong with my lines. I am no beginner but by no means an expert. All posts about this issue seem to be solved with line scaling with LTSCALE. This is not my issue.
No matter what scale I set my line to it will either appear completely solid, or have some kind of erratic dashed line with no discernible pattern.
When i select the line, there appears to be a highlighted dashed line on top of a continuous line. Sometimes when I pan around model space or zoom in and out, the dashed line decides to show up. This is the exact same problem in paper space however for some reason they become visible SOMETIMES for no apparent reason with no way to replicate the solution.
Whats even more strange is that by selecting the line and viewing the weird highlighted dashed line, i can choose a proper scale, and even though in paperspace it looks totally wrong, when i print it, its fine!
Has this happened to anyone before? It is happening with every single linetype also by the way.
Sandro
¡Resuelto! Ir a solución.
