pendean
en respuesta a: antoniostvrgs11
Basic AutoCAD system requirements for an average user:
An i5 or i7 processor running at 3GHZ or higher native clock speed.
8GB Ram
A video card other than a life-sucking Intel HD option with 2GB Ram or more.
If a laptop, 15" screen minimum size: if you want to use it with an external monitor (so you can get a smaller laptop screen), you need to make sure the external monitor can be run at HD display settings (not the low end 1024x768 common on cheap laptops).
A harddrive large enough to hold all of your files: 500GB is good, 1TB is better.
My personal 'upgraded' suggestions for 90% of users out there (you can always add more if you feel you can justify it):
Desktop: i7-7700 clocked up to 4.2Ghz, 16GB RAM (minimum), 512GB SSD (minimum), GTX1080 4GB or Quadro M2000 4GB (minimum)
Laptop: i7-6820HQ, 16GB RAM (minimum), 512GB SSD (minimum), Quadro M2000M 2GB or FirePro W5170M 2GB (minimum)
