Alfred.NESWADBA
en respuesta a: Anonymous
>> In Edit/Preferences you can set the Units under Units/Guides. Under Pages
>> Display you can then set Always show doc page size
That is valid for how Adobe Reader shows units, but that does not tell you anything about which units the PDF itself has stored internally.
I'm not sure, but does the PDF even know anything about mm or cm or m? I guess no and so all you see in Adobe Reader is a converted number from inch to what ever you have set in your settings ... but again, I'm not very sure about that.
>> I have a workload of 129 drawings that has to get the pdf exchanged for a new version
Well, either in one drawing or multiple drawings, as far as I understand you don't do 129 times the same steps manually.
So my guess was which type of automatism do you use to get that done and why can't the imported PDF be scaled (as you wrote that this is no option)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
